Текущее время: Вт дек 30, 2025 20:35
Начать новую тему Ответить на тему  [ Сообщений: 289 ]  На страницу Пред.  1, 2, 3, 4, 5, 6, 7 ... 20  След.
СообщениеДобавлено: Пт июн 19, 2009 2:59
Да, на нашем давлении эти форсунки будут давать 40,1 lbs/hr и 47.5 lbs/hr соответственно.
Если предположить, что стоковое давление для них 13 psi.
СообщениеДобавлено: Пт июн 19, 2009 3:06
Вот инфа из другого ибейного лота
Up for grabs is a fully reconditioned GM TBI 45pph flow matched injector assembly. Injectors + regulator + injector pod gaskets. This came stock on most 1987-95 4.3L V6 trucks, Silverado, Sierra, S10, Blazer, Caprice, Roadmaster + more and is a significant upgrade for your 305/5.0L TBI motor
This injector assembly is a great replacement for those tired, leaking injectors, or would be a significant upgrade for your 305, 5.0L V8 – yes that’s right. These flow more fuel than your stock 305 40pph injectors. Why are the 4.3L injectors bigger than the 5.0L you ask? The injector fires once per intake cycle, since the 4.3L draws in more air per intake cycle (i.e. the 4.3L cylinder is bigger than a 5.0L cylinder) then the injectors need to spray more gas
If you want to make some serious HP – you need this injector pod
Injector part # is GM 5235203 RPD – Yellow/Blue tops
This has never been installed on a motor since rebuild – and my have some dirt or marks as it is a reconditioned assembly.
This will easily feed a 150-225hp motor at stock TBI pressure (13psi) or run with our adjustable fuel pressure regulator at higher pressure for up to 275hp motors.
Included is:
· 100% reconditioned and flow matched injector assembly – as shown – ready to make some serious HP
· Injectors, regulator, injector pod gaskets + injector pod
· Fits any 4.3L TBI application – 1987-1995 at 13psi line pressure
· Good upgade for your 1087-95 5.0L Camaro, Firebird, Full size truck/SUV + more
· Use on motors up to 275hp w/ custom PROM and higher fuel pressure
· File photo - injector assembly received may look different
Universal for most GM TBI 220 setups used in Camaro, Firebird, Caprice, Roadmaster, Corvette mid/full size trucks, Tahoe, Suburban, and much more.
Хороший апргейд для вашего Камарро, Файерберда ну или пары Эскортов 1,4...
СообщениеДобавлено: Пт июн 19, 2009 3:18
http://www.dms-tech.ru/dmstech46.htm
СообщениеДобавлено: Пт июн 19, 2009 3:22
http://www.dms-tech.ru/dmstech54.htm
СообщениеДобавлено: Пт июн 19, 2009 3:41
http://myfiero.oceanmoon.com/?p=50
Может кто-нибудь мне объяснить, что такое 'TBI bore'?
СообщениеДобавлено: Пт июн 19, 2009 3:44
Вот опять:
Код:
GM TBI injectors, color codes, and flow rates
These injectors are rated at the pressure used by the factory, about 13 PSI
Color code Application Flow rate Part #
Black/White 1-3/8" bore 2bbl, from 2.8l truck ??? GM 5235430 *RPD
Yellow/Blue 4.3L ??? GM 5235203 *RPD
Green/White 5.0L 40 lb/hr GM 5235279 *RPD
Orange/Black 5.7L pickup 55 lb/hr GM 5235206 *RPD
Yellow/Brown 5.7L Cop Car 65 lb/hr ???
Blue/Black Late big block pickup 80 lb/hr GM 1708430 *RPD
Dark Red/Dark Blue big block pickup 90 lb/hr GM 5235231 *RPD
The picture below shows where to look to find the color codes in the injector. This picture is of a 4.3 throttle body. The injectors have a yellow/blue color code, each of which is visible on top of the injector.
СообщениеДобавлено: Пт июн 19, 2009 14:13
Текс.
Сходил на почту.
Весит форсунка 99 грамм (с упаковкой будет порядка 120 грамм), доставка ее до Америки будет стоить 92 рубля.
СообщениеДобавлено: Пт июн 19, 2009 18:11
dsa, возможно где-то я и ошибся с расчетами, не столь важно :).
Другой вопрос - если у тебя проблемы с форсункой, не проще ли купить другую б\у? Посылать в Америку, конечно, экзотично и романтично, но рискованно и б\у должно получиться дешевле. Хотя, конечно, из Америки в итоге должна вернуться "почти новая" форсунка :).
Fiesta'96, 1.1HCS CFI
СообщениеДобавлено: Пт июн 19, 2009 19:11
Я, конечно же, не собираюсь посылать свою форсунку, пока не заполучу подмену.
Просто любая БУ форсунка будет примерно в том же состоянии, что и моя собственная. Их менять между собой особого толку нет.
Где ты ошибся то? У тебя должно было получиться 2 числа - время, которое была октрыта форсунка и количество сгоревшего за это время топлива. Тут сложно ошибиться.
СообщениеДобавлено: Пт июн 19, 2009 21:21
dsa, позиция ясна :)
Вернемся к цифрам и расчетам. Заходим по ссылке http://www.megamanual.com/v22manual/minj.htm.
Там есть форма "Compute Flowrate", в нее закидываем 50 и 60 лошадей (это HSC CFI 1.1 & 1.3 соотв.). Получаем 29.4 и 35.3 lbs/hr.
Чуть ниже формула "1 lb/hr ~ 10.5 cc/min" + там формочка-конвертер, из которой получаем 309 и 371 cc/min (см3/мин) соотв.
Т.е. в моем пред. посте ошибки вроде нет. Так как в моем случае имеет смысл оценивать форсунку по большей мощности мотора, то мои эмпирически установленные 365 см3/мин очень смахивают на теоретическо-приблизительные 371 cc/min.
СообщениеДобавлено: Пт июн 19, 2009 21:26
snowdon писал(а):
...Там есть форма "Compute Flowrate"...
В этой форме поставлен BSFC 0,55, а я склонен думать, что у наших моторов он пониже - 0,45 (хотя, не найти достоверной информации пока).
Я пересчитал на 0,45 все выше и перевел твою экспериментально полученную величину в lbs/hr.
Вопрос только в достоверности этой экспериментальной величины.
Можешь еще несколько раз ее получить?
СообщениеДобавлено: Пт июн 19, 2009 22:12
dsa, внимательно вкурил про BSFC. Согласен, твои 31,8 и 26,5 будут более близки к истине.
Пересчитать мою экспериментальную велчичину можно (только пока надо ждать, пока выкатаю 120-150 л. бензина), но вряд ли это сильно качнет текущий результат, так как БК с данной величной не пока давал повода для сомнений от заправки к заправке :)
СообщениеДобавлено: Вс июн 21, 2009 3:10
что вы загнались о производительности? вопрос в другом! посмотрите на распылители. у них-факел,а у нас ссыт на стенки моника. это нормально?
СообщениеДобавлено: Пн июн 22, 2009 0:45
На какие распылители смотреть? Куда у нас ссыт?
У нас ссыт потому, что старые форсунки у всех. Должно также распылять факелом.
А производительность нам нужно знать, чтобы правильно подобрать замену.
СообщениеДобавлено: Ср июн 24, 2009 21:21
да я вот о чём.
tj1_1_2_194.jpg [ 13.54 КБ | Просмотров: 7848 ]
t_cfi_injector_5_136.jpg [ 59.36 КБ | Просмотров: 7006 ]
