Текущее время: Вт дек 30, 2025 14:42
Начать новую тему Ответить на тему  [ Сообщений: 289 ]  На страницу Пред.  1, 2, 3, 4, 5, 6 ... 20  След.
СообщениеДобавлено: Вт июн 16, 2009 18:24
Во, нашел интересный лот:
Fully reconditioned and flow matched GM TBI injectors 55pph 5.7L injectors GM injector part # 5235206. Fits 1987-95 GM twin injector TBI motors V6, V8, 2.8L, 4.3L, 5.0L and 5.7L. This is a significant upgrade for your 5.0L motor (305 came stock with 40pph injectors) or your 4.3L V6, is a drop-in replacement for your 5.7L V8. Big upgrade for you 2.8L guys.
Fits the following applications: 1987-95 mid and full size Chevrolet / GMC trucks w/ 5.7L. 1987-92 TBI Camaro and Firebird w/ 5.0L. Caprice, Roadmaster, Astro, Safari, S10, Blazer. Will fit other GM TBI applications, please email if you have specific fitment questions.
This has been fully reconditioned with the following operations performed:
Electrical test consisting of amperage draw test during operation. This is much more thorough than a simple ohm test and no other ebay seller offers this
Injectors ultrasonically cleaned and spray pattern checked
Back flow cleaned to remove any contaminates that can't get past the nozzle....no other ebay seller does this operation
Flow match to within 5% - stock can vary by more than 10%
Injector bodies polished.....please note....some injectors will have discolorations from ethenol use
New injector o-rings and pod gaskets included as shown
At stock pressure, this will supply enough fuel for motors up to about 240hp, or you can upgrade to our adjustable fuel pressure regulator for motors up to 325hp. Please note, the figures below are estimates and will require some PROM work if you have made major modifications to your motor.
run at stock fuel pressure 10-12psi - for 180-240hp motors
16psi - for up to 280hp
20psi - 300hp
25psi - 325hp
If you have done exhaust and/or intake work on your 5.7L - you will want the extra fuel this puts out
This is a stock photo we use for several injector types and your actual product may vary...however, function will be exactly as stated
Две форсунки на 2,8 - по одной на каждые 1,4. :)
Теперь мы знаем, что они работают на давлении от 0,7 bar до 1,7 bar.
При этом увеличением давления достигается увеличение производительности.
5,7L_GM_TBI.jpg [ 24.67 КБ | Просмотров: 7083 ]
СообщениеДобавлено: Вт июн 16, 2009 18:39
И еще если предположить, что 40 pph - это 40 американских пинт в час, то стоковая производительность для этих форсунок 5,2 мл/сек.
СообщениеДобавлено: Вт июн 16, 2009 19:51
dsa поспортные данные: 4,8 - трасса при постоянной скорости 90 км\ч, 6,9 - городской режим. Средний получается 5,85.
У меня средний расход по БК такой (преимущественно город, поездки на 10-15 км):
- при температуре > 20С: 6,0 - 6,2
- при температуре 10C - 20С: 6,5 +- 0,1
- при температуре 0C - 10С: 7,0 +- 0,1
- при температуре -10C - 0С: 7,0 - 7,5
- при температуре < 10C: 7,5 - 8,5
При этом не топлю, езжу обычно оккуратно, без "нервов".
Fiesta'96, 1.1HCS CFI
СообщениеДобавлено: Вт июн 16, 2009 20:58
Текс, pph - это скорей pound per hour. Они же lbs/hr.
Соответственно, 40 pph будет 0.00503991522 кг/с или (плотность бензина возьмем порядка 760 кг/м3) 6,63 мл/c.
Последний раз редактировалось dsa Чт июн 18, 2009 20:27, всего редактировалось 1 раз.
СообщениеДобавлено: Вт июн 16, 2009 22:58
А вот еще интересно - при каком давлении форсунка выдает 40 pph? (С учетом вышеуказанного разброса рабочего диапазона 0,7 - 1,7 Бар)
СообщениеДобавлено: Вт июн 16, 2009 23:03
Стоковое давление 10-12 psi, тобишь 0,7-0,8 bar.
СообщениеДобавлено: Ср июн 17, 2009 19:22
Мне тут на основе вышеприведенной информации мысль пришла такая: можно попробовать поднять рабочее давление в нашей системе и посмотреть, что будет.
Ситимэн как то пробовал пережать обратку (что в принципе тоже повысит давление, только экстремально). И говорил, что после этого машина поперла серьезно.
Я думаю, что вполне могут уже наши уставшие форсунки не давать нужного потока на штатном давлении, повышение давления придаст им силы, а EEC-IV скорректирует длительность впрыска в сторону уменьшения, если что.
СообщениеДобавлено: Чт июн 18, 2009 0:22
Новая по Экзисту 32 килорубля,а моник в сборе 71. они что,с дуба рухнули? :shock:
СообщениеДобавлено: Чт июн 18, 2009 0:37
Я думаю его просто сняли с производства и забыли.
Вон у америкосов полно контор, кототые эти форсунки восстанавливают.
Они их на свои маслкары ставят до 350 лошадей...
СообщениеДобавлено: Чт июн 18, 2009 0:39
Нашел кстати конторку, которая за 1200$ продает полный комплект TBI, мол ставьте вместо карбюратора, как хорошо! :)
СообщениеДобавлено: Чт июн 18, 2009 1:48
http://www.megamanual.com/v22manual/minj.htm
Приблизительный расчет производительности форсунки по мощности двигателя и еще кое-каким параметрам.
Да и вообще прикольная ссылка на эту тему.
Последний раз редактировалось dsa Чт июн 18, 2009 2:16, всего редактировалось 1 раз.
СообщениеДобавлено: Чт июн 18, 2009 2:10
6. Injectors. GM released 5 sizes of TBI injectors (actually more but those are the important ones) 40lb/hr for the 4.3L and 5L engines, 55lb/hr for 350 engines, 65lb/hr for cop car 350 engines and (80lb/hr and 90lb/hr) for 454 engines. Depending on how much horsepower you make you may need on of the other injectors. While your at it make the regulator adjustable. http://www.thirdgen.org/newdesign/tech/tbi-afpr.shtml Also, consider a new fuel pump FPG001 from www.apeusa.com as the stocker is only good for about 270hp and isn't worth crap. On sizing injectors, most give me all their info and I recommend injector sizing and fuel pressure settings but primarily 40lb injectors are ok up to 200hp, 55lb injectors up to 320hp, 65lb injector up to 350hp and 454 injectors from 350-450hp. Although its hard to make the 450hp with the cam restrictions for speed density fuel injection.
http://www.tbichips.com/v6mods.htm
СообщениеДобавлено: Чт июн 18, 2009 14:15
dsa, серьезно взялся за тему :)
по твоей ссылке провел расчет форсунки для моего авто. форсунка у меня 6796513, ставилась на HCS 1.1 и 1.3, т.е. 50 и 60 л\с соотв.
Получаем 309 и 371 см3\мин. Итого - мои 365 близки к истине :)
СообщениеДобавлено: Чт июн 18, 2009 20:53
Только давайте лучше уже будем в lbs/hr величины указывать, так как на всех американских форсунках так указано.
Только формула еще учитывает BSFC:
Код:
InjectorSize = (HorsePower * BSFC) / (#Injectors * DutyCycle)
А он для нас скорее всего равен 0,45, а не 0,55.
BSFC is the amount of fuel your engine uses to make 1 horsepower for one hour. It is usually between 0.42 and 0.58 at wide open throttle. Normally aspirated engines with efficient combustion processes are at the lower end of the BSFC scale [~0.45], supercharged engines tend to be towards the higher end [~0.55].
Так что для CVH 1,4 в котором 71 сила получается 71*0,45/0,85 ≈ 37,6 lbs/hr.
Для HCS 1,3, в котором 60 сил: 60*0,45/0,85 ≈ 31,8 lbs/hr.
Для HCS 1,1, в котором 50 сил: 50*0,45/0,85 ≈ 26,5 lbs/hr.
А у тебя получилось 34,8 lbs/hr почему-то...
СообщениеДобавлено: Пт июн 19, 2009 2:19
Мы тут пока переписываемся с Робом из injectors4u.com.
Он говорит, что под наши флоурейты подходят 2 из GM форсунок: 5235130, у которой 38 lbs/hr, и 5235203, у которой 45 lbs/hr.
А еще говорит, чтобы я ему прислал форсунку, он ее переберет и флоурейт замерит заодно.
Это удовольствие стоит $25 работа и $35 отправка обратно.
Пойду завтра узнавать на почту, сколько будет стоить доставка форсунки до Америки.
