We often look for games to build things up—cities, empires, or character stats. But sometimes, after a long, stressful day, you don't want to build; you just want to break stuff. If you are looking for a way to blow off some steam in the most spectacular way possible, you need to check out
Solar Smash. It is a planet destruction simulator that is surprisingly relaxing, visually stunning, and oddly satisfying.
What is the Game About?
At its core, the premise is simple: you are given a realistic 3D model of a planet (Earth, Mars, or even fantasy worlds), and your only goal is to destroy it. There are no time limits, no high scores to chase, and no "game over" screens. It is a sandbox experience where you play the role of a cosmic force of nature. You have an arsenal of tools ranging from realistic threats like asteroids and nuclear missiles to sci-fi horrors like alien lasers and eldritch space monsters.
Getting Started: The Gameplay Loop
The beauty of this game lies in its simplicity. When you load it up, you are greeted with a spinning Earth. On the side of the screen is your toolkit of destruction.
Select Your Weapon: The menu is categorized into different types of attacks. You have natural disasters (meteor showers, black holes), man-made weapons (nukes, satellite beams), and alien technology.
Target and Fire: Using your mouse or finger, you simply tap or click on the planet where you want to strike. The physics engine takes over immediately. If you drop a nuke, you'll see the mushroom cloud rise and the shockwave ripple across the continents. If you summon a black hole, watch the planet warp and tear apart.
System Smash: Once you are bored of destroying a single planet, you can switch to "System Smash" mode. This allows you to play with orbital mechanics, smashing planets into each other or hurling them into the sun.
Tips for Maximum Chaos
While mashing buttons is fun, there is actually some depth to how you can dismantle a world in Solar Smash. Here are a few things I’ve learned while playing:
Drill to the Core: Don't just scratch the surface. Use the laser beams to slice the planet in half. If you cut deep enough and expose the molten core, the planet will eventually destabilize and explode from the inside out.
Customize Your Planet: You aren't stuck with the default Earth. You can customize the population density, water levels, and even the color of the atmosphere. Creating a custom world makes destroying it feel a bit more personal.
Find the Secret Planets: The game has several hidden "secret" planets you can unlock by performing specific tasks. For example, turning the Earth into a flat pancake or a giant snowman requires creative use of the freezing and flattening tools. It adds a nice layer of discovery to the destruction.
Why You Should Try It
It sounds aggressive on paper, but Solar Smash is actually quite a chill experience. Watching a planet glow red-hot from asteroid impacts or seeing lights flicker out on the night side of Earth as civilization collapses is strangely mesmerizing.
Whether you have five minutes to kill while waiting for the bus or want to spend an hour experimenting with orbital physics, this game delivers pure, unadulterated fun. It’s a great reminder that sometimes, the best way to decompress is to watch the world burn—virtually, of course. Give it a try next time you need a break from reality.
