Текущее время: Пт янв 16, 2026 14:39
Начать новую тему Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней.  [ Сообщений: 1134 ]  На страницу Пред.  1 ... 18, 19, 20, 21, 22, 23, 24 ... 76  След.
СообщениеДобавлено: Ср дек 08, 2010 22:47
* Do you sell the light version on ebay?
It will be much easier to buy...
СообщениеДобавлено: Ср дек 08, 2010 22:58
eecfo
I can't. Paypal refuses to transfer funds to Russia. So I sell only on the ex-USSR territory.
There're other people in Britain, Czech Republic and Argentina. We did some protocol investigations together and make a kind of an agreement about our sales. We've divided the worldwide market in some way :)
Where are you from? What Ford are you driving? :)
СообщениеДобавлено: Чт дек 09, 2010 14:57
* I am in Bulgaria.
Does your version work with the prog ForDiag 1.20 ?
It seems to have all the gauges, adaptation tables etc or you have own version which works with the little board ?
Old Zetec 94 gasoline EEC IV (has the 2 pin serial bus plug, 18, 19).
СообщениеДобавлено: Чт дек 09, 2010 15:12
eecfo
Tomas developed his own adapter board and software called ForDiag. So as I did. My board works only with my software called AlphaReader.
Why don't you want to buy the Tom's board? Czech Rep. and its post office is much closer to Bulgaria than Russia. Also his board still has more features than mine (but I'm chasing him more or less :) ).
СообщениеДобавлено: Чт дек 09, 2010 16:09
* I will contact him ok.
Do you know or have actually somewhere the docs which describe the original Ford protocol DCL ? etc pdf or other?
СообщениеДобавлено: Чт дек 09, 2010 16:17
* I have some serial<->rs485 adapter, I was thinking could a connection be established without a micro-controller in the middle but directly PC to Ford.
If there was the protocol description somewhere I may attempt to establish
and read some stats to see if this would work.
СообщениеДобавлено: Чт дек 09, 2010 16:20
* Or do the same thing with a smaller PIC controller.
СообщениеДобавлено: Чт дек 09, 2010 16:31
eecfo
google for "LHBH0 strategy guide". Chapter 13. That will be a kind of protocol description.
You can use simple RS485 adapter to switch EEC to CART mode and get a continuous flow of empty frames. But you need a microcontroller to match the perfect timing required to transmit data to EEC between frames.
СообщениеДобавлено: Чт дек 09, 2010 19:52
* Actually bought the Tom's adapter to save time.
It would be great if russian version of paypal appears, or similar service (may be russian made) is established, and it would make trade of such items much quicker and easier for all sides.
СообщениеДобавлено: Пт дек 10, 2010 14:05
Помогите пожалуйста. Незнаю где спросить, который OBD стоит на Мондео И в 1993 году.
OBD I или OBD II. Буду очень благодарен.
СообщениеДобавлено: Пт дек 10, 2010 15:52
На этих мондюках не было никакого OBD. Читай ветку сначала.
СообщениеДобавлено: Пт дек 10, 2010 16:18
Creator Я тоже хочу поставить диагностику, куда мне ее подключить.
СообщениеДобавлено: Сб дек 11, 2010 0:25
А зачем она тебе нужна?
СообщениеДобавлено: Сб дек 11, 2010 13:27
remont1977 как для чего, чтобы не лазить все время под капот и не диагностировать по светодиоду
СообщениеДобавлено: Сб дек 11, 2010 16:11
peleh_sm
на самом деле "OBD" там есть.
Но это OBD I, и он довольно мало требований предъявлял к диагностике. Грубо говоря, "диагностика должна быть" и остальное на откуп производителя :)
[ Time : 0.045s | 15 Queries | GZIP : Off ]
