Текущее время: Вт дек 30, 2025 8:00
 Заголовок сообщения: Моторные масла для МБ.
СообщениеДобавлено: Пн мар 19, 2007 7:40
Автолюбитель
MB sheet 229.1 approved oils
for passenger cars with gas and diesel engines, used to be minimum spec for latest (98+) engines, high detergent, dispersant spec suitable for normal drain intervals. Based on ACEA A3, B3. Note 229.1 oils are not recommended for MB's latest (2002+) 4 valve gas M271, M275, M285 and diesel OM646, OM647, OM648 engines.
Aral Super Elastic 0W-40 Unal
Aral Extra Turboral 0W-40 Unal
Aral BasicTronic 10W-40
Aral SuperTronic 0W-40
Aral HighTronic 5W-40
Aviasynth 5W-40
Avia Turbo CFE 10W-40
BP Visco 5000
Castrol GTD Magnatec 10W-40
Castrol GTX5 Magnatec 10W-40
Castrol GTX3 15W-40, 15W-50, 20W-50, 10W-40
Castrol GTX2 15W-50
Castrol GTX 15W-50
Castrol GXL 10W-40 ACEA A3/B3
Castrol Formula RS 0W-40
Castrol GTX3 Professional 15W-40 (Castrol's best mineral oil)
Castrol GTD 505 01 TOPUP 5W-30
Chevron Supreme SAE 5W-40
Chevron Supreme Semi-Synthetic SAE 10W-40
Elf Excellium 0W-40
Elf Synthese
Esso Ultra
Esso Uniflo
Fuchs Titan Supersyn SL 0W-30, 0W-40, 5W-40
Fuchs Titan UNIC MC 10W-40
Fuchs Titan UNIC Plus MC 10W-40
Havoline Synthetic 5W-40
Havoline Formula3 X1 Extra 10W-40
Havoline Formula3 X1 Diesel Extra 10W-40
Hellas Super Synto 0W-40
Hellas Hermes Plus 15W-50
Kendall Motor Oil Elite 0W-40
Liqui Moly Diesel Synthoil 5W-40
Liqui Moly High Tech 5W-40
Liqui Moly HC7 5W-40
Mobil 1 with SuperSyn 15W-50
Mobil 1 TriSynthetic 5W-50, 15W-50, 0W-40, 5W-40 (100% synthetic)
Mobil Super M 15W-40 (mineral)
Mobil Super S 5W-40 and 10W-40 (mineral w/ synth additives)
Motul 6100 Synergie 10W-40
Motul 4100 Turbolight 10W-40
Pentosin Pentosynth TS 10W-40
Pentosin Pentosynth 5W-40
Pentosin Pentoturbo 15W-40
Pentosin Diesel 10W-40
P.O. Zirve
P.O. Zirve Ekstra
Pennzoil Synthetic European Formulation 5W-40
Performanx Full Synthetic Motor Oil 5W-40
Schaeffer Micron Moly 5W-30
Schaeffer Micron Moly 10W-40
Schaeffer Supreme 7000 10W-30
76 Pure Synthetic Motor Oil 5W-40
Shell Helix Ultra 5W-30
Shell Helix Plus 5W-40
Shell Super Motor Oil 10W-40
Sunoco Forza SAE 15W-40
Ultra Turbo Semi-Synthetic Motor Oil 0W-40
Valvoline All Fleet Extra 15W-40, 20W-50, 10W-40
Valvoline SynPower
Veedol SUPER X-TRON 10W-40
Veedol SUPER X 15W-40
MB sheet 229.3 approved oils
for passenger cars with gas and diesel engines with extended drain interval indicator FSS up to 20,000 km, or 40,000 km - 25,000 mi, current minimum spec for 1998+ MB engines, min. 1.0% fuel saving compared to 229.1, based on ACEA A3 B4. For gas engine of the M100 series, gas engines of the M200 series and diesel engines of the OM600 series (not models with Euro 4 diesel particle filters).
AGIP EXTRA HTS 5W-40
AGIP Synthetic PC 0W-40
AGIP Eurosport 0W-40
Amsoil 5W-30 Synthetic Motor Oil
Amsoil 10W-30 Synthetic
Amsoil Series 3000 5W-30 Heavy Duty Diesel
Aral SuperSynth 0W-40
Aral Super Tronic 0W-40
Aviasynth 0W-40
Castrol DCO TOPUP SAE 0W-30
Castrol Formula RS Road and Track 5W-40
Castrol GTX7 DYNATEC 5W-40
Castrol Formula SLX 0W-30
Castrol TXT SOFTEC PLUS 5W-30
CIFAB Synthoil Hydrocrack HC7 5W-40
Elf Excellium LDX SAE 5W-40
Esso Ultron 0W-30 (fuel economy)
Esso Ultron 5W-40
Fuchs Silkolene Pro S 5W-40 - 100% Synthetic Oil For All Race Engines
Fuchs Silkolene Pro S 10W-50 - 100% Synthetic Oil For All Race Engines
Fuchs Titan SuperSyn SL 0W-30
Havoline Synthetic DS 0W-30
Kendall GT-1 Full Synthetic 5W-40
LUKOIL SYNTEETIK 5W-40
Mobil 1 SuperSyn European Car Formula 0W-40
Mobil 1 SuperSyn 5W-40
Mobil 1 SuperSyn 5W-50
Mobil 1 Turbo Diesel 0W-40
Mobil Synt S 5W-40
Mobil Synt S Turbo Diesel 5W-40
Mobil Syst S 5W-40
Motul 8100 E-Tech 0W-40
Motul 8100 X-cess 5W-40
Pentosin Pentospeed 0W-30 VS
Quaker State Full Synthetic European Formulation 5W-40
Schaeffer Micron Moly 5W-30, 10W-40
Schaeffer Supreme 7000 5W-30, 10W-30, 20W-50
Shell Helix Plus S 5W-40 (Mercedes-Benz)
Shell Helix Ultra 5W-30, 0W-40, 5W-40
Sunoco Synturo Gold 5W-40 (introduced January 2002)
Total FINA First 5W-40
Total Quartz 9000 5W-40
Valvoline DuraBlend MXL 5W-40
Valvoline SynPower MXL 0W-30
Valvoline SynPower 5W-30, 0W-40, 5W-40
Veedol POWERTRON 5W-30
Veedol SYNTRON 0W-30
MB sheet 229.31 approved oils; LA "low ash" Oils
Mercedes pioneered this new spec for passenger cars with diesel engines with EURO 4 or Bluetec exhaust particle filters, e.g. W211 E200 CDI, E220 CDI. The spec was introduced 7/2003. They are called LA "low ash" or "low SAPS" oils, low on sulfated ash, phosphorus and sulphur to limit exhaust particle filter pollution. In 2004 the ACEA introduced the new C3 spec (mid SAPS, normal viscosity) based on it. Change intervals extend to 15,000 km.
Aral Tronic 229.31 5W-30
BP Visco 5000 MB 5W-30
Castrol FORMULA SLX Turbo Diesel 0W-30
Castrol TXT Softec MB 5W-30
Fuchs Titan GT 1 5W-30
Liqui Moly TopTec 7000 LA
Low SPAsh Motorenцl 5W-30 (DaimlerChrysler)
Midland Synqron 5W-30
Mobil SHC Formula LA 5W-30
Mobil 1 ESP Formula 5W-30 (from 3/2005)
Pento High Performance 5W-30 LA
Shell Helix Diesel Ultra AE 5W-30
Shell Helix Ultra AE 5W-30
Wintershall ViVA 1 topsynth alpha LA 5W-30
40
Aral SuperTronic 0W-40 LOW SAPS (ACEA C3)
Castrol GTD Magnatec 5W-40
Fuchs Titan GT 1 10W-40
Liqui Moly TOP TEC 4100 5W-40
Midland Synqron 5W-40
Motor Gold Mid SAPS 5W-40
Motul SAE 5W-40 Vollsynthetisch
Pento High Performance 5W-40 LA
MB sheet 229.5 approved oils; "MB Longlife Service Oils"
for passenger cars with gas and diesel engines with extended drain intervals beyond 229.3 oils, to 30,000 km, min 1.8% fuel saving, first oils introduced summer 2002. ACEA A3 B4. For gas engines of the M100 series, gas engines of the M200 series and diesel engines of the OM600 series (not models with Euro 4 diesel particle filters).
229.5 engine oils must be used with fleece oil filter designed for use with 229.5 engine oils.
AGIP Formula LL DC 5W-30 (I)
Aral SuperTronic G 5W-30 (D)
Aral SuperTronic M 5W-30 (D)
Castrol DCO TOPUP 0W-30 (D)
Castrol Syntec European Formula 0W-30 (USA)
Elf Excellium 229.5 5W-30 (F)
FormulaShell Ultra AB 5W-30 (GB)
Fuchs Titan Supersyn SL MB 5W-30 (D)
Labo MB 229.5 5W-30 (F)
Liqui Moly Longtime High Tech 5W-30 (D)
Mobil 1 SuperSyn European Car Formula 0W-40 (USA)
Mobil 1 Turbodiesel 0W-40
Mobil SHC Formula MB 5W-30
Motorex Profil M-XL 5W-30 (CH)
OMV full syn MB 5W-30 (A)
Pennzoil European Formula Ultra 5W-30 (USA)
Premium Synthetik Motorenцl 5W-30 (DaimlerChrysler, D)
Quaker State European Formula Ultra 5W-30 (USA)
Shell Helix Ultra AB 5W-30 (Mercedes-Benz) (GB)
Shell Helix Ultra DC 229.5 (GB)
Total Quartz 229.5 5W-30 (F)
Valvoline SynPower MB 5W-30 (NL)
MB sheet 229.51 approved oils; low ash long life
Mercedes pioneered this new spec for passenger cars with diesel engines with EURO 4 or Bluetec exhaust particle filters and longer service life than the 229.31 oils. The spec was introduced in 2005. Change intervals increased to 20,000 kilometers. Based on ACEA A3 B4 and C3.
Amsoil European Car Formula 5W-40
Aral SuperTronic 229.51 0W-40 LOW SAPS
Castrol Longtec Turbodiesel 0W-30 (229.51)
Fuchs TITAN GT1 229.51 SAE 5W-30 (first fill oil in OM 642)
Mobil 1 ESP Formula M 5W-40 (to become available in the USA on 5/15/06)
Mobil 1 ESP Formula 5W-30 Emission System Protection (Europe, from 12/05)
Shell Helix Ultra AX 5W-30 Mercedes 229.51
Valvoline SynPower MST 5W-30 229.51 (added 6/1/2006)
http://www.whnet.com/4x4/oil.html
Расстался с МВ 190, (W201).
СообщениеДобавлено: Ср ноя 26, 2008 9:03
Я в свой мерс лью мобил 10в40 синтетика, полёт нормальный!
мерин s500 long ПАРАХОД!
СообщениеДобавлено: Вс май 10, 2009 23:05
А я в свой БМВ лбю Ликви Моли Топ Тек
СообщениеДобавлено: Пн май 11, 2009 0:06
Mobil 1 TriSynthetic 5W-40 (100% synthetic)
only Mobil 1 ;)
СообщениеДобавлено: Пн май 11, 2009 2:46
тут тема по мерсам
ЗЫ. так БМВ уже куплен?
СообщениеДобавлено: Пн май 11, 2009 10:18
Дело в том что я хочу новый, совсем новый, прямо с автосалона, но не покупать модели какие там стоят, а купить под заказ, вот и интересуюсь может у кого фото есть, а может быть и мерс тоже, там есть такие модели?
СообщениеДобавлено: Вт май 12, 2009 15:11
ну так все просто: mercedes.com и bmw.com - там все модели, по тюнинговым вещам спроси отдельно,
вообще такие разговоры с оглашения бюджета надо начинать
СообщениеДобавлено: Вт май 12, 2009 15:20
и явно не в этой теме поднимать сей вопрос.
Kotik по мерсам могу подсказать, стучись в личку, если чего
СообщениеДобавлено: Вт май 12, 2009 16:00
