Текущее время: Вс дек 07, 2025 22:03
Правила форума
 Заголовок сообщения: MMOexp Borderlands 4: Which Vehicle Is the Best
СообщениеДобавлено: Чт окт 23, 2025 8:59
Vex's reward for Borderlands 4 Boosting reaching Level 50, the Skimmer, is a lightweight speed demon. Its Hoverdrive component provides unmatched cornering and top speed, letting you zip through maps faster than any other vehicle. If you love style and flair, the Skimmer is the ultimate flex.
Which Vehicle Is the Best?
While every vehicle in Borderlands 4 can handle anything the game throws at you, the "best" one ultimately depends on your playstyle. Since all vehicles share the same primary weapon systems - rapid-fire guns and rockets - it really comes down to how you like to move and handle.
If you prefer tanky builds, go with the Carapacer or Rockslider. If speed and style are more your thing, the Sprintcraft or Skimmer will feel right at home.
The real game-changer, however, lies in Hoverdrive customization. Once unlocked, you can tweak boost strength, speed, and handling across any vehicle, meaning even the base Digirunner can be turned into a high-performance powerhouse with the right setup.
Final Thoughts
Unlocking all ten vehicles in Borderlands 4 not only helps you earn the Catch-A-Ride trophy, but it also gives you plenty of options for exploring every corner of Pandora's newest frontier. From the early-game Digirunner to the high-level Vault Hunter exclusives, each vehicle adds its own flavor to the mayhem. Sufficient Borderlands 4 Money will also be of great support to you.
So hit the road, crank up the boosters, and show the wasteland who's boss - one burnout at a time.
If you've already helped Ole Shammy once before in Ain't No Sham in It, you know the eccentric brewer has a knack for turning chaos into craft beverages. Now he's at it again, looking to bottle up his next great (and probably explosive) invention. The Brew-ha-ha mission continues Shammy's saga of spirited experiments - and it's packed with humor, geysers, and plenty of loot.
Here's the full walkthrough for completing Brew-ha-ha in Borderlands 4, including objectives, locations, and rewards.
Mission Details
Quest Giver: Ole Shammy
Prerequisite: Complete Ain't No Sham in It
Rewards: Cash, XP, and Eridium
You can start this mission by meeting up with Shammy at his pub, Shammy's Shack, located at the southernmost edge of the Fadefields. Once you've finished his previous side quest, a mission marker will appear above his head. Talk to him, and he'll excitedly rope you into helping with his newest boozy brainstorm.
Step 1: Talk to Ole Shammy
Approach Shammy behind the bar, and you'll be greeted with his usual mix of slurred enthusiasm and brilliant insanity. He explains that he's been "inspired by the elements" and needs help sourcing special materials for a new drink that's literally bubbling with flavor.
Your first task? Track down a geyser that's rumored to spout "flavor-infused nuggets" - the perfect ingredient for his brew.
Accept the mission to receive your waypoint and the first objective.
Step 2: Find and Unclog the Geyser
Open your map and mark your next destination: the Haywire Shire, a coastal area just south of your current location. Fast travel or drive your way there. As you approach, you'll spot a cluster of steamy rock formations and a faint glow coming from one of the geysers - that's your target. Having enough Borderlands 4 Money will be of great help to you.
When you arrive, Shammy contacts you over the ECHO to mention a small "issue." The geyser seems to be clogged - again. If you completed his previous brewing escapade, you'll remember how to fix this: a good old-fashioned ground slam.
Climb up the ledge overlooking the clogged geyser. Once you're directly above it, jump and perform a ground slam (by pressing crouch while mid-air). The impact will blow open the geyser, sending up a plume of colorful mineral nuggets.
Shammy cheers you on over comms, thrilled that his "flavor geyser" is back in business. But the hard part is just beginning - now you've got to collect the right nuggets to make his experimental brew.
Step 3: Collect Colored Nuggets for the Brew
As soon as the geyser is active, you'll notice nuggets of different colors bursting into the air and landing nearby. A brewing machine sits just a few meters away - that's where you'll toss the nuggets in to mix the drink.
Shammy's voice will guide you through the brewing process, calling out which color nugget he needs next. You'll need to Borderlands 4 Boost throw the correct-colored nuggets into the machine in sequence.
