Текущее время: Вт дек 30, 2025 23:59
Начать новую тему Ответить на тему  [ Сообщений: 20 ]  На страницу 1, 2  След.
 Заголовок сообщения: шо за хрень power saver
СообщениеДобавлено: Сб дек 25, 2010 0:06
http://www.buyincoins.com/50kw-power-sa ... t-913.html
Super Intelligent Digital Energy Saving Equipment!
Adopting The Most Advanced, Intelligent, Digital Technology to Save Energy!
Saving Electricity Means Saving Money! Saving Money Means Earning Money!
Features
* Save Electric Power Resources
* Protect the environment
* Surge Protection
* Improve power factor
* Stabilize electrical current
* Reduce waveform distortions
* Protect the appliances and prolong their life
* Reduce Electrical Overheating
* Easy to Use, Maintenance free
* Fully compliant with safety standards
Product Introduction
* Congratulations on purchasing this product people are always eager to find new ways to save money and increase profits.
* With many companies striving to remain profitable in an increasingly competitive global market and with a new international focus on the need for energy conservation, imagine the savings and business opportunities available to you with this new invetion that is proven to save up to 35% in electricity costs.
How It Works
* This Power Saver use a state of the electrical technology to actively monitor and improve the power factor of your household or office appliances. In addition, the intelligent technology optimizes the voltage and current demands thus reducing the active power/ KwH demands and achieves up to 35% savings on your electricity bill. It reduces waveform distortions. It also acts as a voltage stabilizer by storing emery for up to 10 seconds and therefore suppliers the load with constant voltage during momentary power surges. As a result, this power saver prolongs lifespan of the electrical appliances.
Versatile For Use in
* Shops, homes, restaurants, offices, factories (single phase), etc.
Technical Parameters
* Voltage Range: 90 - 250 Vac, 50Hz/60Hz
* Working Temperature: -15°C to 60°C or 5°F to 140°F
* Single Phase Model
* Use one Power Saver for every 50,000 watts
Installation Procedure
* Plug this device into a wall socket, not an extension cord or multiple socket and switch on the unit.
* When you see 1 Blue LED light turn on, the unit has started saving electricity.
* Install one power saver to each phase.
Notes
* This device operates by adjusting the power factor of the incoming supply into your house. For it to work optimally, it should be installed as close as possible to the point of entry of your electricity supply so as to detect all loads before the meter and adjust the power factor accordingly, If it is installed too for down into the circuit, it will not be able to affect the electricity supply to other appliances ahead of it.
* Most effective with inductive receivers (e.g. Motors, transformers, fluorescent lighting, etc.)
* Reduces wave form distortions.
* Surge protecion.
* No movable parts.
Магия Дэвида Блэйна?
СообщениеДобавлено: Сб дек 25, 2010 14:54
* Уменьшает искажения формы волны.
* Скачок protecion.
с промта... ну как он вернет синусоидальность треугольному напряжению я хз, хватит ли его на стабилизацию - тоже вопрос, но если бы хотя бы защита от пиков работает по типу их срезания - и то хорошо.
Короче, некий кондиционер сетевого напряжения.
СообщениеДобавлено: Вс дек 26, 2010 2:18
я как то привык что чем то подобным занимается что то типа http://www.aes.ru/stabilizer/product/1260/
Модель: R4500
Мощность нагрузки, кВА: 4.5
Предельный диапазон входных напряжений, В: 135...275
Точность выходного напряжения, %: 4.5
Рабочий диапазон входных напряжений, В: 155...255
Изменение нагрузки: 0...100
КПД, %: 95
Габариты ВxШxГ, мм: 440x265x385
Масса, кг: 30
Цена: 22.100 руб.
вот эта штука, при желании, синус подправит как надо, и от скачков напруги избавит. От кратковременных отключений, правда, наверное, не спасет.
Но сомнительно что тот задохлик вообще что то сможет.
СообщениеДобавлено: Вс дек 26, 2010 2:27
Use one Power Saver for every 50,000 watts -там же написано 1шт на 50 вт
СообщениеДобавлено: Вс дек 26, 2010 2:33
В ссылке на продукт написано 50kW
пс "reducing the active power"
я помню что это от холодильников, кондеев и прочей заразы такая штука по сети бегает - если кто помнит электротехнику - поподробней объясните плз.
СообщениеДобавлено: Вс дек 26, 2010 16:13
скорее всего автомсетически с помощью ключей или другой элементной базы и конденсаторов правит косинус фи
СообщениеДобавлено: Вс дек 26, 2010 17:17
ну хорошо, но ведь оно должно тогда иметь и вход и выход, чтобы подключаться и к сети и иметь выход на потребители.
Или я чего то недогоняю?
пс ну и провода там к девайсу больше киловатта-двух не выдержат
вот здесь видео подобной хрени - только опытный образец.
работает у них все. магия.
http://www.energy21.ru/downloads/video/vech_1.wmv
СообщениеДобавлено: Ср дек 29, 2010 0:28
надо почитать (погуглить) на тему компенсации реактивной мощности
СообщениеДобавлено: Ср дек 29, 2010 2:05
В принципе, да. Как минимум девайс должен знать ток в нагрузке (и его фазу), и напряжение на нагрузке (и его фазу).
Если девайс не в разрыв, то в разрыве должен стоять, к примеру, трансформатор тока.
СообщениеДобавлено: Чт дек 30, 2010 3:35
ну вот статейка мона почитать http://electricalschool.info/main/elsnabg/14-dlja-chego-nuzhna-kompensacija.html
СообщениеДобавлено: Чт дек 30, 2010 3:45
Ну, в общем, как я понял, все что касается реактивной мощности и прочего - полная туфта, этот прибор ничего не сможет сделать, поскольку должен быть сконструирован специально под определенную нагрузку и тип включенных приборов.
Скорее всего там будет просто конденсатор с "неонкой". В лучшем случае.
Имеет смысл (особенно у кого напряжение отлично от номинала более чем на 10%) покупать стабилизатор. Но в обычную квартиру такой прибор будет весить не менее 20 кг. Остальное все не стоит внимания.
СообщениеДобавлено: Чт дек 30, 2010 3:49
да, я уже курс на их сайте вывешенный скачал. но мужик - явно не преподаватель. бубенит чото под нос себе.
пишут что генераторы этой реактивной мощности - компрессоры, трансформаторы.
но в современной бытовой технике уже стоят компенсаторы, и ничего дополнительно не нужно.
пс я как раз помню как нам мужик по электротехнике гундосил что на предприятиях ставят трехфазные асинхронные двигатели вхолостую крутиться, чтобы они эту реактивную мощность потребляли
СообщениеДобавлено: Пт дек 31, 2010 1:50
yur_capricorn, плохо электротехнику учил ;)
Как раз трехфазные асинхронные двигатели вхолостую имеют аццки низкий косинус и засирают сеть реактивными токами. А то о чём ты вспоминаешь - наверное трёхфазный синхронный компенсатор.
И ничего в современной бытовой технике такого не стоИт.
Собсна, в "бытовых" сетях компенсация реактивной мощности практически не нужна. Актуальна для производственных предприятий...
СообщениеДобавлено: Пт дек 31, 2010 2:09
По сабжу - это действительно мини-конденсаторная установка для компенсации реактивной мощности.
Если внутри неё вообще чё-нить есть ;)
Сомневаюсь, что при этих размерах она обеспечит "50,000 watts"
В зависимости от мощности нагрузки и косинуса должна плавно или ступенчато менять ёмкость конденсаторов. Да вот беда, дабы знать ей эти параметры, надо вход-выход, как писали выше, а нету :-(
Если там кондёр не регулируется - будет перекомпенсация реакт. мощности, т.е. толку - нуль.
Вообще штука в быту малополезная...
Вот ещё похожая хрень, кто купит потестить? ;) http://www.ultramagazin.ru/index.php?productID=45744
СообщениеДобавлено: Пт дек 31, 2010 3:55
Кто сказал что я ее вообще учил? Честно признаться, я вообще из университетского курса мало что усвоил.
Тем не менее, это никак не мешает мне интересоваться различными сложными девайсами, пытаться понять их принцип работы и оценить целесообразность покупки.
Я только помню как мужик говорил, что для компенсации реактивной мощности стоят и вертятся без нагрузки двигатели. Какие - не помню. Потому что щас даже не помню разницу между асинхронными и синхронными (если последние вообще есть).
Но если будет нужно - найду, изучу, разберусь и посчитаю.
Все под конкретную задачу. А глубина изучения задачи пропорциональна величине возможной выгоды. Ну, впрочем, наверное, у всех так же.
Возможно, но так написано во многих статьях на эту тематику.
Я так и понял.
ДмитрийМ писал(а):
Вот ещё похожая хрень, кто купит потестить? Подмигиваю http://www.ultramagazin.ru/index.php?productID=45744
если та хрень ничего путного не делала, то эта должна даже немного вредить - тоесть потреблять.
Как я читал в отзывах на нее в иноземных магазинах - там сидит кетайске блок питания от мобильника с отрезанным выходом и неонка.
Зец ол!
[ Time : 0.068s | 14 Queries | GZIP : Off ]
