Текущее время: Пн янв 19, 2026 10:48
 Заголовок сообщения: Arc Raiders: Jupiter Blueprint Guide
СообщениеДобавлено: Пн янв 19, 2026 8:19
What is the Jupiter?
The Jupiter is a bolt-action sniper rifle that uses Energy Clips. It cannot be upgraded, meaning the stats you see when you craft it are what you will use in combat.
Here’s a quick overview of the weapon’s key stats:
Damage: 60
Fire Rate: 7.67
Headshot Multiplier: 2.0x
Range: 71.7
Stability: 73.5
Agility: 39.2
Stealth: 5
ARC Armor Penetration: Very Strong
Weight: 9.0
Magazine Size: 5
Sell Price: 27,500 Coins
In practice, the Jupiter is designed for high-damage, long-range combat. Its slow handling and low stealth mean you’ll mostly want to use it from a distance or in controlled engagements.
How Effective is the Jupiter in Combat?
The Jupiter stands out because of its raw damage and armor penetration. Compared to other weapons, it has:
High damage against shields: A headshot on a player with Light or Medium Shields often leaves them with less than 30 HP.
Strong ARC penetration: The rifle can pierce enemy armor and hit core systems directly. This makes it highly effective against bigger ARC types like Bastions or Bombardiers.
Cost efficiency: If you aim carefully, 10 well-placed shots can destroy larger ARC units.
Players tend to use the Jupiter in scenarios where they can maintain distance and pick targets methodically. Rushing in with this weapon usually backfires because of its slow rate of fire and low agility.
How Do You Get the Jupiter Blueprint?
To craft a Jupiter, you need a Jupiter Blueprint. Blueprints are often earned through missions, events, or purchased from the market. If you don’t want to grind extensively, one safe method is to buy ARC Raiders blueprints safely on U4N, which is a trusted marketplace that many experienced players use.
In general, having the blueprint is mandatory before you can craft the rifle, so securing one is the first step in acquiring a Jupiter.
What Materials Are Needed to Craft Jupiter?
Crafting the Jupiter requires three main components along with the blueprint and a Gunsmith skill level of 3:
3× Magnetic Accelerators
3× Complex Gun Parts
1× Queen Reactor
Once you have these, you can craft the weapon directly. In practical terms, players often gather these materials by farming ARC enemies, completing specific missions, or salvaging other weapons.
It’s worth noting that crafting a Jupiter is not cheap, but the weapon’s combat effectiveness makes it a worthwhile investment.
How Do You Repair Jupiter?
Like most high-tier weapons, the Jupiter will eventually degrade with use. Repairing it restores durability and requires:
2× Magnetic Accelerators
1× Complex Gun Parts
Each repair adds +50 durability to the weapon. Players often keep a stock of Magnetic Accelerators for both repairs and crafting other weapons, as these tend to be in high demand.
Can Jupiter Be Recycled or Salvaged?
Yes. If you no longer need a Jupiter or want to reclaim parts, you can recycle or salvage it:
Recycling: Returns 2× Magnetic Accelerators and 1× Complex Gun Parts.
Salvaging: Yields 3× Advanced Mechanical Components.
Many players use recycling to recover components for crafting new weapons or repairs. Salvaging, on the other hand, is more valuable if you’re farming for mechanical components for higher-tier crafting.
Tips for Using Jupiter Effectively
Based on common player behavior, here’s how to get the most out of the Jupiter:
Use distance to your advantage: The bolt-action rifle has high damage but slow handling. Stay behind cover and pick shots carefully.
Aim for the core: Thanks to its armor penetration, targeting cores on larger ARC units saves ammo and is faster than repeatedly shooting shields.
Pair with faster weapons: Since Jupiter is slow, carry a secondary weapon with higher agility for close-range encounters.
Manage ammo: With a magazine size of only 5, every shot counts. Plan reloads around safe moments or after taking out key targets.
Repair proactively: Don’t wait until durability is critical. Keeping the weapon at a high durability ensures it doesn’t fail mid-mission.
Common Questions About Jupiter
Q: Can Jupiter be upgraded?
No. Unlike other weapons, Jupiter’s stats are fixed once crafted. Players focus on precision and ammo management instead of upgrades.
Q: Is Jupiter better than other sniper rifles?
In raw damage and ARC penetration, yes. But it is slower and less agile. Compare it to your playstyle and mission type.
Q: How do I get the components efficiently?
Magnetic Accelerators and Complex Gun Parts can be farmed from ARC enemies or obtained through salvaging other weapons. Queen Reactors usually come from higher-level missions.
Q: Should I sell or keep a spare Jupiter?
Many players keep at least one spare for salvage or emergency crafting. Selling can provide coins but may cost more in resources long-term.
The Jupiter is a high-damage sniper rifle built for players who prefer precision, planning, and controlled engagements. It excels at long-range fights and ARC-heavy missions. While crafting and repairing it requires effort, the weapon’s performance justifies the investment.
Whether you’re aiming to take down heavy ARC units or dominate in PvP scenarios, understanding how Jupiter works in practice—its strengths, limitations, and maintenance—is crucial. Securing a Jupiter Blueprint, gathering materials, and learning to use it strategically will give you a solid edge in the game.
What You Should Know: ARC Raiders – Heavy Fuze Grenade: Crafting Recipe, Get, Best Use
[ Time : 0.046s | 15 Queries | GZIP : Off ]
